Kick starter gets stuck ?
Only thing to do is pull the clutch cover off and check the mechanism. Compare it to the picture in the manual. Install kickstarter lever and rotate shaft gently through the stroke. May want to remove spark plug so there is less resistance.
  • Helpful 1
