Onzalimey
Desperately need help with my idle bog
This is a 2017 Husky TX300. Has a Kiehn carb on it. Same carb my last bike had which was a husky 300 2017 and it ran great on that. I bought the bike off someone and it had a MIkuni on it and still felt dull on the low end. Anyway, it bogs under low RPM load and I cannot for the life of me figure out why. Also the low end power seems not so great. Went from a 35-45 pilot and a few in between. Changes the mixture but the bog doesn't change with any of those jets. Maybe a touch worse with a 35. And it has to have the air screw all the way in or its way worse. Had the carb off, looked clean, float bowl is good. No cracks in either side of the boots that I can see. Just replaced the reeds with V force. Compression feels good on the kickstart and the bike has tons of power in the high rpm. It has a FMF powercore shorty on it and I'm not sure if that would cause issues. Cylinder looks good from visual inspection. Power valve seems to work and is clean. Put a new plug in it. Don't know what else to do.....
Silencer has been repacked, jetting has been changed a ton. The bike itself runs much better on good jetting obviously but no matter how rich or lean on all jets and the slide it still will bog off idle. I even put my buddies 300 stock silencer on it and nothing. Seems extremely odd it wants to bog off idle even with good jetting. My buddy is pretty good at jetting bikes and we tried to troubleshoot everything and nothing. Just seems so weird to me.
2 hours ago, weantright said:
Is it smoking a lot? Loss of gear oil?
When I went rich it obv smoked lots. But on proper jetting it’s normal
Im having a little trouble understanding your post. You added the Keihin and its bogged since then?  Is it a real carb or a knockoff? Slide cutaway? What needle?
What slide are your running?  Needle?
Edited by mxaniac
1 hour ago, Onzalimey said:
It’s not a jetting issue. Even though it sounds like one. Trust me
You used this same carburetor on a different 300 and it was jetted correctly?  Was it bogging on the Mikuni or just not jetted as lean as you would like?  If the carb swap caused this then we look at air leaks on the intake boot and dirt in the read block.  If you did the carb swap because the bike didn't run well then we look at:
compression (measure it)
clogged silencer
crank seals
blown head or base gasket
ignition timing
Rag in the air box boot (it's happened).
Try it with the kill button unplugged.
Change fuel
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
