yamaharider250f
YZ125 Broken stud
Got the stud out today. Lots of patience with a left hand drill bit and an extractor. I have new studs, tomorrow I'm picking up new gaskets and orings. I had a power valve cover bolt break as well. Any titanium upgrades out there for an 04?
  • Like 6
  • Helpful 2
No joke. Hot water and dish soap. And a Scotchbrite pad. Rinse the soap off and blow with compressed air, then spray WD40 all over it. The WD40 will displace any water you can’t see.
  • Like 3
4 hours ago, Motox367 said:
150$ 😳😳 dam lol
Actually it’s $85 if they can bench it $150 if it’s still in the vehicle/frame. I snapped off my flywheel bolt in my ranger crankshaft and they buzzed that baby out for $150. Way cheaper than pulling out the crank
Plenty of Titanium fasteners for any bike if you want to spend the coin. Just remember, dissimilar metals like to corrode, so always use an anti-seize on any fastener of dissimilar metal, (Stainless in Aluminum, Titanium in Aluminum, etc)
I agree with putting a fender washer on it first as they are large and will prevent weld splatter on the cylinder and then a nut on the broken stud then weld the nut on, I’ve removed lots of these non broken studs and sometimes they can be tough to remove to the point that they might snap off at that point I soak them in penetrating fluid and heat up the area around the stud and spray a little more after heat and then they will turn out so any other way but welding might jeopardize getting it out
Niiiice bud. Bet your STOKED!!!
You bet I am! Thank you for all the suggestions guys!! Good point about dissimilar metals, I'll just pick up an OEM bolt
I see you removed the stud but I found this. This guy uses a copper pipe and a mig welder.  The pipe protects the surrounding area from the mig. Pretty cool.
Before welding a nut onto and rosette welding i'd take a nut, drill out removing threads as well opened up to just fit over the broken stud. In the lathe cut a shallow taper so the nut contacts the aluminum first near the stud and not the full face of the nut damaging the machined surface. Rosette weld, let cool while appling penetrating oil, wait overnight while applying low heat near the side by the stud expanding the aluminum before torquing it out.  I didn't see the ccondition of the other studs and if not looking like new i'd replace all of tjhem as mentioned above.......~~=o&o>.......
Great video as well the person in it explaining his process. Years ago read an article with photos on Tig welding copper to stainless, ity can be done.....~~=o&o>.......
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
