Eli A
Dinli Dino 50cc Carb Issues
I'm fixing up a Dinli Dino for a buddy and am having some issues with the carb. I have already cleaned it all the way out. The floats are 100% clear and it isn't overflowing so the floats are working, but I believe it is overfilling the bowl because it won't start unless you give it some throttle while kicking. It then proceeds to sputter while it burns up the extra gas and then it runs great. If you leave it idling after running it will very slowly choke itself out with gas again.
Any suggestions? I have considered the floats may need adjusting to shut off earlier but I don't wanna try until I know how to if they can be adjusted.
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
