150r /250r counter balance shaft
Posted (edited)
have a knocking type of noise coming from my bottome end I was able to pin point it with a long screwdriver up to my ear and it is heard the most at the waterpump cover behind the propellor. I remove the side case. And found that the counter balance shaft behind the waterpump shaft has play back and forth and wanted to know if that was normal when I push and pull on it it makes a cluncking noise.? I have took the whole top end apart also looking for somthing that could be chasing the noise anyone have experience with there counter balance shaft clunking while the engine is running??
Edited by Justin Cruz Castillo
