1994 Suzuki rm125 clutch problems
Posted (edited)
I own a rn 125 and before I had to service the clutch it worked perfectly fine, then once I took it apart it’s not disengaging. The basket is in good condition as well as the plates but I notice there is play  in the clutch cover pinion shaft help? Once I Put it out together the clutch lever would pull in easy but not return
Edited by Thomas Hopkins
Check for a return spring unhooked or broken, the cable routing/connection or something along those lines. You put something together wrong
Sounds like a simple adjustment, at the perch, or at the lever by the engine... something is not allowing full release. Does the cable have free play?
