Vacuum bleed
Hi everyone,
make a Quick search but found nothing so what’s better for vacuum bleeding
- doing it by the reservoir ?
- doing it by the comp adjust ?
sorry for language i’m not expert in english !
And thanks to all That make this forum so intéresting
Adio Corsicanbiker. I did both and prefer through the reservoir because I think I trap less air installing the bladder or piston than installing the comp adjuster Best is the KTM bleed screw style at the top of both chamber in my opinion.
Thank’s you for your response. Just asking because i found 2 sets of adapters for vacuum shock at aprox the same price one for the res and the other for comp adj.
i think it need more cycle to bleed by the reservoir due to the comp adj valving and not put the hose at the Highest point of the shock than doing it by the comp adjuster ?
but as you said maybe trap less air when puting the piston or bladder
