2006 yz250f SSS forks extremely soft?
I have some 2006 yz250f sss forks that i rebuilt, but they feel extremely soft, when i crank in the compression adjusters all the way in it feels almost normal but still semi soft, i measured my springs and they measured good, i used 5w 85-150 maxima oil, changed the bushings and seals, is there something that i could have done wrong? Or any suggestions on how to make them stiffer? I was thinking new springs but i wanted to get some other opinions
  • Bryan II changed the title to 2006 yz250f SSS forks extremely soft?
10 hours ago, Swedish enduro said:
If your upper seal (that is placed inside the plastic piston above the base valve) is bad you will not have any pressure in the fork and it will feel soft.
Easy two swap tough.
Ok, i’ll take a look sometime soon, thanks
