2022 450X for woods
woodsguy2000
I made the mistake of selling my 2021 450RX,  looking for a replacement. New Hondas are slim pickings around here, but the 450X is available. It's heavier than I like but is set up nice. Anyone running single track, Texas style, lol? My main riding spot is Cycleland in Nacogdoches if you're in this area. 60 miles of varied terrain, now nothing like Colorado. But most is a low 15mph average or so for me. Some sections faster but not by much. Some are pretty technical and might drop to 13 or so average. Unlike the Sam Houston national Forest, my other riding spot when open, we only have a couple of sections with excessive sand and whoops. National forest is much faster, 20+ average. Most of ours is  nice dirt or hard packed. Just wondering how the bike works between the weight difference and little less power than the RX I sold. I know it's a tough question, but little insight appreciated. I've had a couple of X's but think the last was 2012 or so. Bike worked well for me except the national forest whoops.
Not exactly a direct comparison, but I have a Gen 1 450X (2009) and a 2019 450RX.  And from what I'm told, the Gen 2 450X is slightly heavier than the Gen 1, so hopefully pretty similar comparisons can be made--sixth gear and FI notwithstanding.
The 450RX will be better in almost every way in the tight stuff--except for one really important area, power delivery. The RX is such a rambunctious bike with regards to the throttle, that you really need to be slipping the clutch constantly in the slow stuff. Not necessarily bad, just that the gearing is so short and the power hit is so strong, it doesn't really just cruise much.  I run a Rekluse in mine so I can deal with the tight stuff better, and I still find myself using the clutch b/c the power hit engages the auto clutch so fast.  (As an aside, a Rekluse while still using the clutch lever normally is pretty much the perfect setup for me--full control of power engagement in turns and tight sections, and ability to virtually eliminate stalls on the extreme stuff, but I digress.)
The 450X does have that really nice tractor-ability, and I miss that a bit when racing the RX in hare scrambles out west. And the 450X also has that great sixth gear (which you may not be using much it sounds like). But it's so much heavier.  I used to hare scramble my X and now I just do the really fast desert races with it. That's where it absolutely shines.
So with the power hit the RX gives, and the weight the X has, I'd still vote RX for the tight stuff. The weight difference is remarkable while riding. Even a 250RX would be pretty stellar, though I've become addicted to the 450 power for better or worse.  HTH!
Edited by amcjen
  • Helpful 1
Forgot to mention, there's a shop out west that recuts the RX cam and remaps the ECU to make it a bit more "X" style. I'm just about to pull the trigger on that, excited to get the best of both worlds of the RX and X, you may consider that as well.
10 minutes ago, woodsguy2000 said:
The RX hit is a lot for my area but weight bothers me. We constantly have new trees down that sometimes have to manhandle over. And the occasional dropsies.  Lol. Thanks. The RX is available here, just hate buying one after being dumb and selling mine. Long story.  Lol
No I getchu. We've all made those regret sells before.
But if you're thinking the RX is already heavy, you're really not going to like the X.  ~25 lbs difference between the two.
I can’t make a comparison to the RX, but I really enjoy my gen 1 X as a do everything bike here in southwest Colorado. I ride mostly singletrack in the National forest, but also get into double track and some sand/slick rock in New Mexico and Utah. It’s my first big bore thumper since I started riding as a kid. Took some getting used to the power but once you do it’s totally manageable in the woods. I don’t really struggle with the weight/size as I’m 6’5” and 210#.  The truth is that there are a million different bikes out there, and most are specialty use. For me it’s important to pick a bike and learn to ride it as well as I can. You’ll be suprised at what you can do on just about any bike I you’re a solid rider.
Really don't think the RX is especially heavy, it is compared to KTM, but it is very snappy on the bottom end. And yes the 25#'s really bothers me.
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
