Rear brake problem
I have a rieju mrx pro with a broken rear brake. Its like theres no pressure in the break line so i thought the master cylinder was bad. And bought a new one and changed it out for the old one. Still didnt pump any fluid to the brakes. It pumps air, but no fluid comes out no matter how much i try pumping the brakes. Anyone know what could be wrong
Yeah, when the system is completely drained, it's neigh on impossible to just pump fluid through. It's especially bad on the rear brake, since there's no gravity to assist the fluid.
A cheap vacuum bleeder (the hand pump ones) does wonders with these cases, or a big syringe also works on a pinch.
  • Helpful 1
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
