Holeshot device up the outer tube on WP 48mm?
All WP holeshot devices seems to be constructed to sit at the bottom of the upper fork leg where the bushings go and the fork is a bit thicker. It means you have to adjust launch height with fork guards which means you need several fork guards for various positions.
Any issue mounting like a kawi holeshot device on the WP, that can sit in the range 10-200mm above the WP recommend holeshot devices?
Btw, can't find such holeshot device either for WP...?
1 hour ago, chadk66 said:
Why do you desire various positions?
Different surface status. On metal grid i want it as far down as possible, concrete with long start straights higher, dirt with good traction somewhere on between. Sand very low on the fork leg
