HELP!!! 2007 yfz 450
Caleeb
Have a quad that if you just shake the quad at idle or hit any bumps / turn it will shut off. When I shake the quad a little fuel comes out of the bottom overflow port. Float level at 8mm from gasket surface to top of float. It’s driving me crazy!
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
