Solo race sag method
A few years ago I came up with an idea ¬†of using my¬†iPad to take a video ¬†of a hanging measuring tape ¬†to measure and set sag solo‚Ķit worked ok ¬†but eventually I had an accident and cracked the iPad screen ¬†ūüėē
It looked like this (from my YouTube video) :
after I broke the iPad, I tried to use an old HP webcam, (shown below) with a laptop for a live view, and it worked halfway ok….the camera had a hard time focusing and was just 720p resolution…. CE199C7C-2488-4E51-B2DC-45ECC867D4D2.thumb.jpeg.42ac64951a79b2fb7a4130531c52a98d.jpeg
one of the YouTube viewers suggested I try using a GoPro and view it on my phone….I tried it recently and it works well,  have a look.FEEB166A-6E00-4DF4-9BA3-3247E223F163.thumb.jpeg.341e791f31b53407d3c5faace5315c09.jpeg
the measuring tape is a little 1/4‚ÄĚ wide unit that I simply tape to the fender, and it‚Äôs captured at the axle by a small cotter pin¬†
set the camera on a small tripod , jackstand, block of wood, whatever… so you can get a accurate look at the tape through the camera
B8B82D75-F1F5-4615-8F7A-B5785DF4C0A7.jpeg.521a35c7609e9c3e7fdcfdd16e41ce7d.jpegthis is the real-time preview through the gopro app on my phone…
What I usually do is start measuring on the stand and adjust the tape so it reads 705mm at the axle. Then take the bike off the stand and I expect to see about 670-675mm , then I  sit on the bike with gear and  adjust the spring preload for 600mm, which gives me my 105mm of race sag.
you can do a video with your phone  as well but I really like the idea of looking at a real-time image
Hope that helps
Edited by ss-racing66
Typo
  • Like 3
  • Helpful 4
5 hours ago, Hans Schmid said:
Motool Sag Scale
Motool 3080-103 Slacker Digital Suspension Tuner V4 with Bluetooth. Works on street, off-road and adventure motorcycles. https://www.amazon.ca/dp/B08B1FXQC7/ref=cm_sw_r_apan_glt_i_KW7HWYMYWNJ47V9HVN9R
Those are nice , they’ve been around for at least a couple years, but I can’t justify the cost when I might only use it once a year
I use almost the same method.
My difference is that I attach the begging of the tape measure to the axle, and take measurement up top on the fender.
With a phone on a tripod I record the video. Live viewing with two devices would be nice, but my method is routine by now so I don't find it necessary.
I've used that Motool scale once, and while it produce results, it is so low-tech that I'd never consider it at that price. Chinese could make a better device for 10$.
  • Like 2
On 10/14/2021 at 4:40 AM, DrzDick said:
This year I did something similar on my road bike on the front.
I taped a 12" rule to the fender and set my phone up on a mount to video it whilst I sat on the bike and bounced the forks etc.
what's that thing ¬†in the vice?....don't tell me it's a selfie stick ¬† ūüėȬ†
Selfie stick...lol :jawdrop:
That'd be far too easy...
It's a short length of black plastic pipe with a RAM mount clamped on it and on to that is a motorcycle phone mount that I modified to fit a 1" RAM ball.
  • Helpful 1
√ó
√ó
