my bike pops and spudders alot need help ???
ok i just cleaned the air filter and i took it out for a test run and the thing took me 15 min to start, and wile i accelerated it wasent quick on the thottle, also when i let off it pops and sputters what the hell is the problem??
thanx :thumbsup::devil:
It sounds like you got dirt in the carb when you removed the air filter. The dirt can clog a jet and make your bike run lean. Take the filter back off. Make sure your airbox is super clean and with the motor running spray carb cleaner straight into the airboot while reving the engine to prevent it from dying. If that doesn't clean it out you may have to take the carb off for a more thorough cleaning.
A hint for keeping the airbox clean... get a TwinAir airbox cover. With it in place you can wash out your airbox with a high pressure hose without getting water in your carb. :thumbsup:
