JD I need your help
I have a all stock 2004 CRF250X and I have a bad bog off the bottom. What should my jetting be at 1200' and at 70 to 80 degrees? Thank you for the help!! :thumbsup:
I recently bought a JD kit and ride from elevations of 1000-3500 feet. I also had a terrible bog/hesitation at low speed acceleration. I followed the instructions and put in a 158 main jet, along with the clip in the 5th position down and have lost all hesitation. The bike is much more responsive and more fun to ride. I also cut the airbox when i re-jetted. I do not like spending money, but this sure cured my problem. Good luck with it.
If you're trying to work with stock parts, turn the fuel screw outwards and keep the idle set high. A richer clip position change may be needed if the problem persists.
James
