Assembly Lube mixing with Oil
Is it worth changeing the oil since I just put hotcams in and some assembly lube. If not, about how much riding time should I change it?
I don't think the assembly lube will have any negative effect on the engine oil, if that's what you're getting at. You didn't fill up the whole top of the engine with it or anything did you?
If you used moly based assembly lube it's a good idea to get it out of the engine before it has a chance to hurt the clutch plates. An oil change is still cheaper than a clutch change. :thumbsup:
Well listen to Rich, not me. I wasn't aware of the fact it could degrade your clutch performance.
