Chain lube that looks like tacky white lithium grease?
Anyone know the brand of chain lube you can buy that goes on like extremely tacky white lithium grease? I think the lube looks like the tacky white grease that comes on a new chain, or what you see on a chains on the bikes at the dealership. It's not Maxima chain wax.
www.belray.com
Sounds like the stuff - thanks.
"General Description
Bel-Ray Super Clean Chain Lube is a high performance motorcycle and 'O' ring chain lubricant for road and off-road applications. Its unique formulation in convenient aerosol containers sprays on a lubricant white in color that will not fling off once dry and will not attract dirt or sand."
CB Daddy I have the Bel-Ray and it works great. The straw that you squirt the stuff with, make sure you blow out the excess lube thats in there or it will tack up and the straw will be useless. It doesn't wax up immediatly it takes a few minutes. I can see myself running out of it really fast because it takes a lot to get a good lube.
