WR250F front brake issues?
At first I thought it was a steering head bearing issue, but as I started taking the bike apart, I noticed that the front brake rotor seemed very loose. The reason I thought it was the steering bearing is because when I would hold the brakes and compress the front end, I would feel an odd motion type of popping feeling. How loose is the rotor supposed to be? It appears to have bushings holding the actual rotor in place. What should I do to correct this problem? New rotor? New bushings? :thumbsup:
