Burms??
when i first started riding i used to go on the inside of burms now i go on the out side and i cant work out which is quicker! what do all of use do?
The short answer is which ever line inside or outside that alows you to maintain your speed. A few exceptions: Like maybe your behind a guy and he goes wide and the corner is sharpe enough for you to Square off the corner and get past him. Usually the sweeping corners the fastest way around is the outside berm. Sharper corners it kind of depends on what your trying to do. Hope that helped :thumbsup:
Whichever sets you up for the next obstacle. Could be inside, middle, could be outside.
Yea, usually if you have a big jump coming right out of that corner, you want to get outside to keep your speed and momentum. I try to stay outside too because the inside is really rutted and I'm horrible at ruts.
