Pictures of my 01 converted to 04.
I bent my subframe, so I decided to do what someone did in the 450 forum. I converted to an 04. Parts:
subframe
airbox assembly
rear master cylinder
Tank (stock size that I dyed black)
Hurricane kit
SDG Seat
Couple homemade brackets to hold down tank.
While I was at it, I got carried away and swapped swingarm, and linkage to the 04 along with an RCS Titanium Spring. Took a while but it's done and rides great. Exactly like my 04, but with more power due to the 280 kit and cams. It's so good I'm going to get rid of the 04 for an 05 450. I can post more pictures later when the light is better.
I love the way these look with the yellow and black scheme. How did you dye your tank black? Why couldn't you do the same with your fenders, only yellow? Bike looks badass. Nice job.
Do you notice any difference with the wave rotors from stock? Just curious.
I actually bought all black plastic to see how it looks with the kit. And it looks good. The dye is a last resort to the tank not being available in the stock size. I really cannot tell the difference, but I'm sure a deep scratch will show. The black plastic, I'll prbably run in the mud. Yellow shows no damage.
No, when I bought the bike it had an oversize kit on it, they were full floating and I was never fond of the way they felt compared to my 450 or 250. So I put the setup back to stock with the exception of the wave rotor. But really I have not felt the difference.
Do you ride the track with a FMF "Q"??
Yes, the 280 kit and cams make so much more power then my stock 04, that I never see the need to switch. At places like I5mx and Clubmoto I can still accelerate up the hills with ease at low rpms if needed. I have thought about a Factory 4 though...
Answer to some questions coming my way:
I did not see an easy way to drill into the frame. The brackets were easy, just a 3 inch so strip if aluminum on each side with a nut behind it. It has two holes in it. One to bolt to the frame with a shorter bolt. And use the stock bolts at the other end with a nut behind hte strip. I filed and sanded mine so they were smooth and nice. The 01 and 03 exhaust both line up. I checked with my 04 exhaust. The exhaust in the picture is from the 01. The subframe itself required a tad of filing at the place where the top bolt goes in. I think it's around 1/4". It's obvious when you go to put it on because the 03-04 subframes are centered up there and the earlier ones are not. The airbox does not come with the rubber piece that leads the the carb. I had to go back and get that and the rubber flap above the carb, and the piece that the air filter bolts too. Not very expensive though. My understanding from someone in the 450 forum is that all those pieces can come directly from the 01 and bolt into the newer airbox. Everything lined up with the carb perfect.
Does the powerbomb help with power that much with the "Q" on there? Is it noisier than the stock header with the "Q"?
I think the powerbomb might actually quiet it down a db or 2. I tried the SX model and did not like it.
Nice bike but that E46 is badass. I have one also that has all kinds of stuff done to it. Wide-body kit, 20 inch HRE's in the rear with 19's up front, big brakes, various motor mods etc. What else is done to yours? Are you running 19's all the way around.
Yeah 19" all the way around, HR coilovers, Eisenman Race Exhaust, AC Shifter and strut brace, and Underdrive pulleys.
I ride at club moto every thursday but they said only stock exhaust or quieter but everyones running factory 4 and white brothers and they dont enforce it?
I have been there only a few times, but I'm pretty sure the rules just say to not be 'too loud'. Not sure how to interpret it. But I thought it was around 99db.
sick car, chrome crf. very nice bike, wish i had one like that. i like the frame too, and those wave roters look super trick
