Bike back together PICS
Ive ridden it once since the porting and she ran awesome. Havent had a chance to ride yet with the Hotcams though.
Thats the stock pipe and silencer. I took the heat guard mounts and grinded them off then air sanded it smooth. Also the silencer is stock with the PMB end cap/spark arrestor except I chopped 4" off so it would just tuck behind the side number plate as you can see. I noticed some more bottom-end and a unique sound. But that silencer is sitting on the bench since I replaced it with a Pro Circuit Ti-4 that I found on ebay for real cheap.
What's air sanding??? :thumbsup: I never heard of it.
My bad, I used a tool that connects to an air compressor with a thread on the end that you can attach a grinding wheel, sanding wheel, etc. The air spins the wheel and after I ground the mounts off I sanded it with the sandwheel attachment. Hope this clears things up.
