titanium welding solutions..
If you can tig stainless ti is not much different.
It is not that hard to do.
The bummer is that a 1/2 lb of filler rod is over 100$US.
This certainly isn't my area of expertise, but we do alot of Ti welding at work. The key issue is Ti reacts (titanium dioxide) with O2 at temperature. Standard practice is to inert with Argon gas.
Bill - Do you have to back purge the weld to do it properly? What kind of rod would you suggest for the grade of titanium used in the japanese OEM pipes? One last dumb question, can you weld stainless (321) and japanese OEM titanium together?
Crank up your post purge time and keep the sheild gas covering the weld area until it is no longer wet appearing, this will prevent the oxidation from occuring.
