CRF 530, Jetting advice?
Hi Guys,
Tomorrow me CRF 540 will be ready to start. It has:
99 mm bore (+3mm)
69.5 mm stroke (+7.4mm)
14:1 Compression
+2mm oversized valves
Carb bored 2mm larger
Yoshimura exhaust
I am at 800 feet and about 70 deg. F.
My question is where to start on jetting? What Pilot, Main, and Needle to use?
This is a guess, so jet richer if you're uncertain-
#45PJ (stock '02 CRF)
1 1/2 turns out
Stock needle (OBEKR)
#4 clip position
#180 main jet (slightly bigger for the 2mm oversize)
Adjust the fuel screw as needed, then ride a short distance and check whether the response feels rich or lean and adjust as needed.
Sounds like a fun project bike! :thumbsup:
James
I forgot to mention that I also have a JD Jetting kit to choose from for needles as well if one of those needles might work better.
Thanks
