Check your Carb Joint for cracks..
My sons 03 250F was starting to backfire and then would not start or run w/o the choke on.
I looked down at his carb and noticed his rubber carb joint had a large split in it causing the problem.
This is also an excellent way for dirt to get in bypassing the air filter and trash your engine.
I think the clamps were overtighened from the factory causing the split, as I do not recall ever touching them.
You might want to check yours.
Same thing happened to me but it was my own fault. I did not notice that the clamps should be aligned with the taps on the rubber and after one ride the rubber was torn.
Sami
I didn't know my old carb joint was being recycled. I thought I threw that thing in the trash. :devil::thumbsup:
Seriously, mine had a crack twice that size.
