OEM clutch basket cushions
Where can I get just the cushions from. I am about to rebuild the engine ('02)and wanted to replace the cushions as I noticed a couple were starting to split.
As always links/help appreciated :thumbsup::devil:
I just installed the WISECO clutch system in my engine and the cushions were radically different. Also the Hinson clutch cover is deeper therefore holding more tranny juice (appx. 800cc). It also looks like the clutch basket allows for much better oil flow to the disks. :thumbsup:
Wiseco or Hinson--I put new cushions, basket and plates from Hinson and I couldn't be happier. If you go with a new basket, heat up the basket and drop the gear in the freezer and the gear will drop in nicely with just a little bit of encouragement. And Red Loctite the basket screws, too.
