how to set the timing on a 86 xr 250r
The ignition timing is preset, nothing to adjust. Just assemble and go.
To set the cam timing the piston should be at TDC (T mark on flywheel aligned with the sight hole) the the cam gear is meshed so that the two marks on the gear line up with the top surface of the head.
