My YZF is set up for 125lbs and Im 140lbs - How can I fix?
I bought my bike used with the suspension set up for a 125 lb rider (RaceTech) and Im 140 with gear. I rode the bike and it feels good but a little soft. Am I fine with this valving and can I just change some of the clickers? Which ones do I change? Thanks
Check your sag to make sure its as close as can be. You might also want to drop the forks a mm or 2 or add a cpl. cc's of fork oil depending where the bike balance is right now.
doc
