If i put E headpipe on my S model...
will it be enought to feel difference (Allready have aftermarket exhaust and remove tube from airbox. i dont know which jets in carb) or i shouldn't replace it ?!
You will also need a E mid/muffler because the E headpipe is a bit larger...3mm.
I replaced the S head pipe and muffler with E size from FMF. Only other mod was the air box cut out and dyno jet kit. The bike gained mid and top end range but lost a lot on the bottom. Could not do roll on wheelies any more. The bike was carburating cleanly as well. The fix was to put in Hot Cam intake and an FCR carb. The bottom end is back and more.
