CRF250X JD Jetting for 2500-3800 feet elevation
I have a Ca CRF 250X.I have removed the exhaust baffle, cut open the air box, and have removed the secondary air pump.I want to install a JD jetting kit.What will the kit come with to get proper jetting?What will I need to use for proper jetting for elevation from 2500-3800 feet?Can someone please let me know what jets and needles need to be used, and how many turns out, and clip position.I know nothing about jetting, as you can see.thanks. flagoffreedom@yahoo.com
The jetting kit has all the needed parts to jet your bike. Use the sea level to 3000ft elevation setting for your conditions.
The fuel screw makes adjusting the idle mixture easier. Other than that, the fuel screw has no difference in performance.
Thanks,
James
