axle sliders
Is anyone using the SMengineering sliders on their 04 ktm?
If so how do they mount? Their sight shows a threaded rod that go's through the axle which the sliders screw onto. How does this work on ktms with the sealed axle ends?
The nuts are only 1/8" thick in the center.
Simply drill out the nuts with a 1/4" drill and your done.
Harry
Why do you say they are already suspect?
I made my own sliders and used 8mm threaded rod and drilled an 8.2mm hole in the axle nuts.
I dont know, maybe not suspect. The aluminim nut on the rear axle just had me a little concerned. Ill just drill them though.
Making my own has also crossed my mind. Doesnt seem like there is much to it. Johnu, what did you use for the actual slider part? Any advice or parts list you wanted to share would be appreciated. Thanks.
Nat,
I have access to a machine shop at work so I just ordered some 1 1/2" round Delrin (also through work) and knocked them up on the lathe. I made them about 2" long as I recall with chamfered ends. I have tested all four of them and they worked perfectly!
just use a set of skateboard wheels- $25, some threaded rod from home depot= $2.50 and some washers= $.03ea and you've got yourself some sliders that will stand up to numerous get offs... at 1/4 of the cost.
This thread reminds me...
What do you guys w/ late model KTMs use to drive out your front axle?
It has such a thin wall it seems the threads could be easily buggered.
I turned an aluminum slug that fits inside the ID w/ a shoulder that pushes on the wall when smacked w/ a hammer.
Has anybody found a better solution? (Or even thought it was a problem?)
-Tyler
I also pull it out with my fingers. But first I leave the nut on just a few threads and lightly tap it with a mallet just to get it moving.
