jumping WR250F settings ?
Help on settings
is the following information correct. i understand that i will need to do more expermenting i im only after general information this is what i think needs to be done after reading manual
Setting suspention from stock
front shock:increse comperession clikers (bottom clikers)
adjust rebound clikers so fork rebounds slower
increase oil level to prevent bottom out
rear shock:increase high comperresion adjuster to prevent bottom out
increase low comperresion cricker
adjust rebound to allow slower rebound
i am only want to know if i am on the right track
maybe revalve stiffer springs this would cost $$$
thanks
I have done all this except the oil height. Its a major improvement except one huge table top im not quiet clearing and im defintely bottoming out front and rear. If oil doesnt help im gunna go spend a day at Race Tech who does full custo settings + teaches you how to do it all yourself for $800. Where in aus are you.
I have done some expermenting i have found that the clikers on the front set 7 out is a little to hard i have set it 10 out this seems not too hard .Rear shock high comp set about half a turn in from stock.Ihave already set fork oil height
5mm higher.i still need to play with rebound front and rear.As i start jumping bigger i will do some more adjustments.Note this is on the aus model
david
