valve removel-not enough room
I just tried to remove my buddies sons crf250r valves.I borrowed the same valve spring compressor that i used on 2 450's and it will not fit between the head and the spark plug tube.Can you remove the tube?He does not have a repair man. I just figured it would be the same as the 450.This is a top-of-the-line compressor.ANY IDEAS?CLAY
I talked to the folks at web-cam who in turn called kibblewhite,They said another month on ss intakes.So how is everybody fixing their bikes without ss valves?
I heard somebody say pro circuit.Will their valves be as good as kw?THANKS FOR ANY HELP,CLAY
I'm not sure about the compressor, but I got a pretty good idea from someone on here (RHC I think) that said get a piece of tubing (metal) that's the same size as the retainer and cut slots in the side for your fingers. Set the pipe on the retainer and put a socket on the pipe. Give it a quick slap and the clips pop right out. Not the best in the world, but it works.
Good luck.
Does anyone have the website for the PC valves?
