crf450 with Ti4
i just put a FMF Ti4 SL on my 04 crf and was wondering what you would recomend for jetting it correctly. i dont know my elevation but i am in michigan if that helps. i havent had time to ride it yet to take a plug reading but when i first start it and shut the choke off it dies out where it would idle with the stocker
Try turning the fuel screw outwards 1/4 turn to richen the idle mixture and set the idle speed slightly higher. Ride and evaluate to see if the jetting needs to be riched higher in the range with needle clip position or main jet.
James
