Clutch Problems....Please Help!!
I have an 03' yz250f. I changed my clutch cable and now it will not engage. That's all I did was changed the cable, so I am confused as to why this happened. Anyone's help is greatly appreciated.
Thanks, Kim
You might have accidently put on the WR250F clutch cable. It is a bit longer then the YZ250F I think the part # begins with a 5TA-#########. See if it has the 5TA on it.
Good Luck, rease
I do have the correct cable. The lever that the cable is connected to at the bottom is moving freely and does not have a stiff spring like motion so I think when I either disconnected or connected I might have done something to it.
