Won't Start ???
I just put in a set of stock intake valves and everything seemed to be fine. Bike went together fine. Valves are right on spec. Bike just wont fire up. I can bump start it but can't kickstart it. It also doesn't want to hold the idle either. After about 5 kicks or so it backfires then back to nothing. What gives :thumbsup:
The piston is at TDC. Both the cam sprocket and the side case alignment are right on. Is there anyway else it could be out of time?
Checked the decomp clearance. It was at .025. Way outa tolerance. I'll see if this works. Any other suggestions???
Did you have the carb apart? There are 2 pieces to the slide and if the small flat piece is upside down it won't run right at all. If you didn't take it apart take a long hard look at the timing.
