Solution to graphic bubbles?
This is just a thought. Has anybody used the new krylon for plastic on there tanks? If so, did it stay on, I sprayed my front fender, it stayed on good, you really had to work at it to scratch it. Anyway, if the paint stays on the tanks, and does not bubble, that is the most important part. If it does not bubble, do you think it would work as a vapor blocker. Maybe draw around your graphics and spray the tank sides,(does it come in clear?) then after several days of curing apply the new graphics. This is just a thought, may not be a thing to it. I guess we need to hear from someone who has sprayed a tank. I wonder if there is some sort of coating that could be applied inside the tank. :thumbsup:
