DRZ400SM K5 what a crap !!! :-(
TECHNICAL SPECIFICATIONS:
Overall Length: 2,220 mm (87.4 in)
Overall Width: 870 mm (34.3 in)
Overall Height: 1,185 mm (46.7 in)
Wheelbase: 1,460 mm (57.5 in)
Ground Clearance:
Seat Height: 890 mm (35.0 in)
Dry Mass: 134 kg (295 lbs)
Fuel Capacity: 10 litres
ENGINE:
Engine Type: 4-stroke, liquid-cooled, DOHC, 1-cylinder
Bore x Stroke: 90.0 mm x 62.6 mm
Max Power:
Max Torque:
Piston Displacement: 398 cc
Compression Ratio:
Carburettor: Mikuni BSR36
ELECTRICAL SYSTEM:
Ignition Type:
Starter System:
TRANSMISSION:
Transmission: 5-speed, constant mesh
Drive System: Chain
CHASSIS:
Front Suspension: Inverted telescopic, coil spring, compression :15-way adjustable rebound :19-way adjustable
Rear Suspension: Link type, oil damped, coil spring, Spring pre-load : fully adjustable. Rebound: 21-way adjsutable. High-speed comp: 3.5-turn adjustable. Low speeed comp: 20-way adjustable
Rake/Trail: 26.3 degrees/94mm (3.7 in)
Front Brake: 2-piston caliper, 310 mm single-disc brake
Rear Brake: 2-piston caliper, 240 mm disc brake
Front Tyre: 120/70 R17M/C
Rear Tyre: 140/70 R17M/C
Now tell me it isn't an S ?!
rear wheel 140/70 ??? which size of rim is it...
Looks like the suspension got a complete workover, front and back. :devil: Unless I'm confused on the shock. :thumbsup:
So, for the inverted forks... Are they to be street oriented (ie. valving for street), or used for offroad as well? I wouldn't mind that entire suspension.
I want the swingarm too.
Also interested in the exhaust... I wonder what the deal is?
:thumbsup::awww::devil:
S model
i hope this is a typo.it would suck if it has smaller than a 4.25 rim.140 radials are impossible to find.
This topic is now closed to further replies.
