Drives forward in Neutral
When the bike is cold and I push start with the clutch fully depressed the bike has some power and creeps forward. When warmed up, this creeping disappears. Is this normal? Does my clutch need to be adjusted?
your title is misleading.your bike creeps while in gear with the clutch in,not while in nuetral.
how much freeplay do you have at the lever?
should be 5mm or so.
Good point. . .
I think it happens on starting the bike (clutch must be depressed) independent of neutral or in gear.
