Quietest silencer/spark arrestor for CRF450?
I don't want to ignite a flame here. I have:
02 CRF450
FMF powerbomb header
FMF Ti-4 silencer/spark arrestor combo.
It passes the California 96 dbA sound test, just barely. I've repacked the silencer and sealed all gaps with hi-temp silicone sealant, but the bike is still way too LOUD for me at higher RPM and lots of throttle.
A ranger at Hollister Hills CA told me that in his opinion the White Bros E2 is the quietest one around, so I may buy one - but I figured I would ask this group's experience first :thumbsup:
Has anyone here recently tested different silencer/arrestor combos on the CRF450? If you have, pls. post here!
Thanks,
+sean
California, USA
A lot of us run the stock exhaust and just add the PMB spark arrestor endcap plus the Silent Insert. I don't think anybody has failed the sound test with that setup, plus it's pretty cheap. Click on the PMB advertisement on the TT Advertiser's page for more info. :thumbsup:
PMB... Fresh packing puts out 93/94dB on the sound tests in Oregon.
I 1st tried a FMF Q - I really did not like the mounting strap crap, and how far it stuck out the back of the bike (04). Plus I felt, it robbed too much power.
hey zombie! I am running the same set up as you so i bought the fmf silent core insert! It quieted the bike down but took away to much snap so i pulled it back out and cut almost half of the length of it off and put it back in. I am pretty happy with it now, not to loud but still great performance. cost $25.00 give it a shot!
Hey guys - thanks for the opinions.
vtec - Thanks! In fact I do have the quiet core... wonder if the previous owner cut it down already because it's loud. I'll look tonight.
I found this listing from the CA OHV division - it lists actual measurements taken at parks over the last year or so:
http://ohv.parks.ca.gov/default.asp?page_id=23038
I learned three things by reading it:
1) Sure enough, the CRF450s with stock silencers and Pro Moto Billet tips typically measured 92-96db - rather toward the low end of the scale.
2)I've been griping about how loud modern competition 4-stroke bikes are - but I see here that the CR500s I2-strokes I used to ride were just as loud.
3) My 02 KTM 125SX with FMF Q-series is indeed quiet. Those bikes came in at 89-91db.
+sean
vtec, datasponge, and the others -
What kind of packing do you use, that makes it so quiet?
Do you pack it in tightly or sort of loosely?
+sean
I have:
02 CRF450
I thought I'd report back on the progress I made:
I made it quieter when I repacked it this time! Previously it measured at about 96db when I packed it not very tightly. This time I tried something different.
I noticed that around the perforated tube core there is a wrapping of two layers of stainless mesh screen that hold a layer of stainless steel wool inbetween them. This screen wrapping was pretty loose and was puffed out away from the core in many places.
I cinched it down tightly to the core by wrapping safety wire around it at 1 inch (2.5cm) intervals. Then I wrapped the fiberglass packing tightly around it and wrapped that with masking tape. I sealed all the joints with a TINY bit of hi-temp silicone sealant.
Result: the bike is A LOT quieter - it's nice to ride now!
And it measured at 94.3 db at Metcalf yesterday.
So,
was: loose screen-wrapping, lightly-packed fiberglass, 96.5db
now: v. tight screen-wrapping, tightly-packed fiberglass, 94.3 db!
Yippee!! it is pleasant to ride now. :cry:
I have the same set-up 2002 and went from a FMF system like yours and was too loud for a local track (which I respect), so I searched a way to quiet it down and ended up with a White Brothers E2 slip on, and I have to say the thing is so easy to change into a race system, and when i get to the track that sound tests, I slip in the sparkarrestor/silencer end cap and test in the 92-94 range. No noticeable change in power, the only thing different is the delivery just slows down a little. When I had the FMF Ti-4 I put in the "quiet core insert" and the bike nearly choked to death. . .
