Side stand/clutch switch removal
Looking to ditch the sid/clucth switch on my `03 S. Both for weight and the fact it`s pretty pointless. What should I do to get rid of them? Do I join the 2 wires to the clucth? What about the kick stand?
Dunno about the Kickstand switch (don't have one on the E), but this weekend I busted off the wires for the clutch in a crash and just plugged the wires together behind the headlight...worked like a charm.
Rhett
Dunno about the Kickstand switch (don't have one on the E), but this weekend I busted off the wires for the clutch in a crash and just plugged the wires together behind the headlight...worked like a charm. Yep ! good deal there. To overide the stand switch just follow the wires over to the connection and unplug it. Then the connector on the bike needs to be cut off and those two wires joined with a butt connector. I used the heat shrink type :thumbsup:
For the sidestand... remove the switch and connect the wires. :thumbsup: I did the same on my bike for both clutch and side stand.
Remember in case you want to sell the bike, to keep the stock features available. So, don't cut the wire. Buy 2 small female connectors, and make a shunt with a short piece of wire. connect it to the green canned plug under the seat, to short the kickstand switch. If you remove the switch, don't throw it. The next owner might want it.
Also, if your bike ever has to go through an inspection for roadworthiness, it will be required...
not in US :thumbsup::devil:
My side stand was bouncing on the logging roads killing the engine intermittently. I went up below the seat cut the wires spliced and shrink wrapped them. Then when (if) I ever need to put the switch back in the splices will be out of sight.
My mechanic in Ontario, Canada says if it was original equipment, it must be present and functioning to pass a safety. It's a provincial issue so other parts of Canada may be different. US is state-by-state too I assume.
Mine already hit the trash can long ago. Nobody is ever going to want that thing. Nobody is ever going to want to plug up an uncorked bike either.
I took off the side stand switch right away. The connector is by the right hand side just ahead of the upper shock mount on my 2000 DRZ 400S. I thought I would be smart and go to the local Cycle Wreckers and get a connector from a wrecked bike's wiring harness rather than cutting up the side stand harness. The "coneheads" wanted $20. I bought 2 wiring terminals from the cycle dealer for a $1 and loaded the connector with silicone grease and wraped it in electrical insulating tape then high temprature aluminum heater duct tape. I am leaving the clutch lever switch in the circuit because I think you will "smoke" the starter motor if you try to start it in gear many times. Hope this helps you. Eric B.
thats a new one.good to,but not even close to the truth.
Thanks! This posting helped a lot.
Just picked up a new 05 DRZ 400 SM for a screaming deal.
First order of business:
Remove Side Stand switch
Remove air box snorkel
Remove Round front fender Reflectors
Remove Rear Plate holder and reflector
Remove Seat Strap
Remove Passenger Fot Pegs
Add Battery Tender lead
Adjust Clutch and Brake Levers
All of those extra parts I put in a shoe box. Nobody wants them, but it gives the impression that you're organized and meticulous.
When the time comes to sell the bike, it makes a better impression that you have these OEM parts still around.
Next - I need to get a hair dryer to remove all of oddball stickers. Will keep the tire pressure ones, because they're handy to have.
After that- I'm looking for a Corbin seat, K&N air filter. Some kind of after market exhaust and jet kit. Any suggestions on jet kit and pipe?
Thanks
In Arizona, they don't even you at the bike. You just sign a piece of paper saying it's road worthy! Ah the joys of libertarianism.
Rhett
the exact same thing happen to me today, 26th, on our boxing day ride out, works fine, i'm just gonna keep it like that!
Remove Seat Strap
Thanks
Don't forget:
CS sprocket cover
Chain Guard
Bar Ends
Reflector mounting plate
Smog Cannister
Ya, there's a ton of crap to get rid of.
So lets say I wanted to keep the switch for sentimental reasons (OK, maybe
more to be able to put it back on the bike if I sell it :thumbsup: ). Anybody know
where one would get the male part of that green connector to make a clean
short that doesn't require cutting the original wires?
Thanks,
Gustavo
what wires do u connect together for the clutch?? do u just dissconect it then cut it and make it run like a circle?
Unplug the clutch switch then connect the left over wires together. They should be yellow, if I remember correctly. They already have the male and female connectors and everything.
