Thumpertalk genius on eBay
so what does it do that the stock set up wont do?
The real question is what is he replacing it with? He must have a new mod coming. :thumbsup:
:applause:Well its about time the man takes a little
credit for his insight & knowledge ,after all this AMERICA!!
I personally think this was long overdue !! I hope he sells
a bunch of them :thumbsup:
69t/a
Theres no plug wire to go bad.
When a coil wire goes bad, sometimes the arc will go back through searching for a ground and burn out the module.
Nice mod Ed. I hope you sell some.
Same directfire coil setup as on A GSXR...I've had one of these "BURNED performance" coils on my DRZ for about a year now, and really like it. It has a hotter spark that helps in the mid/top end, and seals the plug hole quite a bit better so there is less chance of drowning out the spark plug...this mod also moves the weight of the coil down approx. 6" which helps lower the bikes center of gravity and reduce the top heavy feeling a DRZ has... :thumbsup:Andrew
