CRF fork outer oil change
I used the search and most posts got off track and started talking about oil. :devil:
I just want to make sure that i am changing the oil correctly.On my 2002 crf450.
Here is what i did.
1.Pulled Forks
2.loosened fork caps
3 turned upside down and drained into a pan for 8 hours(@ work)
4.refilled to 395cc
Now here is my question. About how much oil stays in? I checked my manual and it states 3.7cc for my temp and time draining. But when i measured the oil that came out it only measure to 300cc. I just had my forks done by Race Tech and on the setup sheet it says the level was set at 396cc.
So what did i do wrong? :thumbsup:
Maybe monkeyboy at Racetech only put 300cc in instead of 400cc? :thumbsup:
I can tell ya this for sure, if you put 395 back it'll be quite a bit firmer.
Unless they count the inner chamber oil too, which would be completely incorrect :devil:
Maybe monkeyboy at Racetech only put 300cc in instead of 400cc? :awww:
Unless they count the inner chamber oil too, which would be completely incorrect :thumbsup:
Could be seemed like alot of oil to be missing :lol:
I wanted to check it since it bottomed hard off a small flat landing jump.
So Is it safe to assume i didn't miss anything and my oil really was THAT low :devil:
My 02 I have 49kg springs vs 47kg standard I run 400cc's of fluid each leg and mine are plush.
I was going to mention that. I believe heavier springs actually take up more volume (thicker coils)... no??
So anyone know of a friendly cheat sheet???
Unless they count the inner chamber oil too, which would be completely incorrect :awww:
Could be seemed like alot of oil to be missing :devil:
So Is it safe to assume i didn't miss anything and my oil really was THAT low :lol:
Ya, Id say you were safe in not missing anything. And it would explain why it bottomed so hard too....
I bet it was plush over tiny stuff though...
I run 400cc with .49 springs too...but Ive got a subtank set up too, mines really plush... :D
