How the heck. . .
Do you use a manual micrometer? I bought one yesterday thinking I could measure some shims, but &%$#@!?! NO directions, NO clue, nothing! I understand there's .025" measurement on the barrel, and .001" on the barrel, but my math skills are highly lacking right now! Any advice?
I have one... it's in metric, but fairly self explanatory. What exactly would you like to know?
Mine came with no directions. Just a few words on the package that said "Each number on the barrel equals 1.00", each mark in between equals .025" and each mark on the thimble equals ".0001. Take the number off the barrel and add to the thimble to get your measurement." &%$#@!? I tried adding them up and they're no where near the number I get on the shim (i.e. 1.78, 2.02, etc.)
The #'s for the shim are metric, sounds like you have an " micrometer.
Here's the shim sheet so you can convert to .001.
Thank Ride_Red for it.
14901-MBB-000 .0472in 1.20mm
14902-MBB-000 .0482in 1.225mm
14903-MBB-000 .0492in 1.25mm
14904-MBB-000 .0502in 1.275mm
14905-MBB-000 .0512in 1.30mm
14906-MBB-000 .0522in 1.325mm
14907-MBB-000 .0531in 1.35mm
14908-MBB-000 .0541in 1.375mm
14909-MBB-000 .0551in 1.40mm
14910-MBB-000 .0561in 1.425mm
14911-MBB-000 .0571in 1.45mm
14912-MBB-000 .0581in 1.475mm
14913-MBB-000 .0591in 1.50mm
14914-MBB-000 .0600in 1.525mm
14915-MBB-000 .0610in 1.55mm
14916-MBB-000 .0620in 1.575mm
14917-MBB-000 .0630in 1.60mm
14918-MBB-000 .0640in 1.625mm
14919-MBB-000 .0650in 1.65mm
14920-MBB-000 .0659in 1.675mm
14921-MBB-000 .0669in 1.70mm
14922-MBB-000 .0679in 1.725mm
14923-MBB-000 .0689in 1.75mm
14924-MBB-000 .0699in 1.775mm
14925-MBB-000 .0709in 1.80mm
14926-MBB-000 .0719in 1.825mm
14927-MBB-000 .0728in 1.85mm
14928-MBB-000 .0738in 1.875mm
14929-MBB-000 .0748in 1.90mm
14930-MBB-000 .0758in 1.925mm
14931-MBB-000 .0768in 1.95mm
14932-MBB-000 .0778in 1.975mm
14933-MBB-000 .0787in 2.00mm
14934-MBB-000 .0797in 2.025mm
14935-MBB-000 .0807in 2.05mm
14936-MBB-000 .0817in 2.075mm
14937-MBB-000 .0827in 2.10mm
14938-MBB-000 .0837in 2.125mm
14939-MBB-000 .0846in 2.15mm
14940-MBB-000 .0856in 2.175mm
14941-MBB-000 .0866in 2.20mm
14942-MBB-000 .0876in 2.225mm
14943-MBB-000 .0886in 2.25mm
14944-MBB-000 .0896in 2.275mm
14945-MBB-000 .0906in 2.30mm
14946-MBB-000 .0915in 2.325mm
14947-MBB-000 .0925in 2.35mm
14948-MBB-000 .0935in 2.375mm
14949-MBB-000 .0945in 2.40mm
14950-MBB-000 .0955in 2.425mm
14951-MBB-000 .0965in 2.45mm
14952-MEB-000 .0974in 2.475mm
14953-MEB-000 .0984in 2.50mm
14954-MEB-000 .0994in 2.525mm
14955-MEB-000 .1004in 2.55mm
14956-MEB-000 .1014in 2.575mm
14957-MEB-000 .1024in 2.60mm
14958-MEB-000 .1033in 2.625mm
14959-MEB-000 .1043in 2.65mm
14960-MEB-000 .1053in 2.675mm
14961-MEB-000 .1063in 2.70mm
14962-MEB-000 .1073in 2.725mm
14963-MEB-000 .1083in 2.75mm
14964-MEB-000 .1093in 2.775mm
14965-MEB-000 .1102in 2.80mm
14966-MEB-000 .1112in 2.825mm
14967-MEB-000 .1122in 2.85mm
14968-MEB-000 .1132in 2.875mm
14969-MEB-000 .1142in 2.90mm
14970-MEB-000 .1152in 2.925mm
14971-MEB-000 .1161in 2.95mm
14972-MEB-000 .1171in 2.975mm
14973-MEB-000 .1181in 3.00mm
Actually I have a shim with the numbers worn off, so I bought a micrometer to size it up. I'll see what I can do with the spec sheet. Thanks guys!
Also remember the conversion from MM to Inch is.
MM / 25.4 = inch
Ex.
1mm / 25.4 = .03937"
Also if your having problems reading the barrel on a micrometer I could teach you with a few pictures.
Please do! I was looking online last night trying to "learn" how to read the darn thing. Like I said my micrometer is from Sear's and has a row of numbers (1.00) on the barrel, and a vertical row of numbers (.001) on the thimble. Maybe you can walk me through how to measure, record and then convert. Would you believe I have a master's degree?! :thumbsup:
Don't feel bad I work with numbers all day and threw mine out and replaced it with a digital one. The first time I used it I thought I had it figured out, did my measurments and ordered my shims. They all came in way to thick so my neighbor lent me his digi and I trashed a brand new only used once device for a digi.
Thanks a bunch! How do I zero my mic? I see you can spin the barrel off completely and there's a little tensioner nut of some sort on the shaft. There's also some kind of adjuster on the ratchet end as well.
Turn it all the way in but don't force it, it should go to zero. That's what the ratchet is for if you don't have a feel for it.
To properly calibrate it you need to use a gage block but I know you don't have any.
Just see if it zero's out when you turn it in.
