Burned..Final Tweak on my 450 DRZ help SQUIRT
I thought I would move this since it was off topic
Eddie I cant thank you enough for all your guidance. My bike rips, it's perfect for me, everyone here has made getting a DRZ the best choice I could have made.
As far as the final touches it runs like a beast, just that occasional blip of the throttle stall (before taking off, not clutch stall) issue. (doesnt happen all the time either)
Anyway I dont think I want to screw with jetting or anything else since it runs so freakin well. It pops just a little bit on decel when I'm at my lowest altitude, maybe too smooth a tad rich when I'm at 5000ft so it seems nicely balanced but the power is always on tap, no bog of any kind. Scary fast....It doesnt stall everytime either when I blip throttle and never when in gear.
Is 2 seconds before the squirt starts to die off too long? If so I should do that taffy mod? I'm not sure what those tabs do.
pinching or spreading the tabs only affects the point at wich the pump squirts.you have to do the taffy mod to limit the pump.
