JD Help needed '95 XT600E
posted before, but no suggestions offered
1995 XT600E changed to SuperTrapp IDS2 quiet Series, 8 discs installed.
> K&N filter cleaned & re-installed
I'm going to pull the plug this PM, it'll have about 360 miles (secondary roads, about 50 miles interstate) to check color.
pulled plug> shows rich???
problem is, it seems to starve for fuel now after a couple of miles on the superslab.
I usually run the rpms up thru the gears to hit the lane at 65-70 mph in 4th.
it'll be fine then hesitate, hesitate more and lose power like I'm running out of gas.
if I stop and wait a minute of so, it'll be fine again.
any ideas?
I read in another post about modifying the primary fuel bowl to prevent the secondary carb from starving, where do I find the Wrench report it refered to?
Check the fuel line for any kinks, and see that it flows freely. Make sure the tank vent is clear. There may be a screen on the fuel inlet.
Clean the carburetors and check the fuel level in the float bowl. Check with a dealer about the wrench report on the carburetors.
James
