Removal of Backfire Screen
I just removed mine. All I did was separate the metal from the plastic. Did I read where some of you cut the screen? If so why do I need the metal frame minus the screen? Did you have to make any fuel screw adjustments?
If your bike starts popping a lot on deceleration, then open ur fuel screw a little. 1/4- 1/2 turn out, then go from there.. :thumbsup:
Toss the whole screen, Check on the airbox and side panel mods. I added a JD kit, powernow, valve cover breather mod, one up on the rear sprocket and a TI 4 muffler/midpipe.
I would suggest cleaning your filter with non-flammable liquid if you are going screenless. The screen is metal for a reason and it has to do with retarding backfire!
