Bigger oil cooler for XR300?
Does anyone here have a thermo dipstick with their XR300 kit (big bore kit). I just had thumper do a 300 kit on my bike, I'll be putting things back together soon, but am wondering out loud if the 20% increase in displacement will add to much extra heat/thermal load on the oil. It would be interesting to know the oil temps on a stock XR250R, and what oil temps run on an XR300. I know Dwight says the XR250's run real hot, necessitating the use f high quality oil. Just wondering if the engine runs much hotter. If so, I'll be looking for an XR400 oil cooler, which look to have 2-3 extra cooling fins, relative to the stock XR250 oil cooler.
Anyone have any experience with the above, comments, etc?
Thanks in advance.
Mike
I ran an XR250 at its biggest cylinder bore (roughly 289cc), and had no problems at all. This was in tight woods, with lots of hill climbing.
I would add a few extra cc's of oil (2 quarts vs 1.8 suggested), and change it (and filter) every two/three rides.
What did you think of your XR290? Did you notice much power increase? Howd it do on hills? I'm wondering how this 300 will feel.
It was honestly a whole different bike. I used a higher than stock compression ratio on the piston, and ported the head myself with a Dremel Tool. Russel Hicks at Thumper Racing gave me some beginner porting advice over the phone (free...nice guy). Added a bigger jet, and that thing ripped! People used to ask me what size it was. It was the perfect hill machine. Pure traction, with just the right mix of Thump. I used lower gearing too (forget sizes).
That thing was an '87, so I'm sure the '96 and newer models would be a blast to soup up. That '87 started my Thumping addiction really (not counting my first 50cc). Later I had Thumper Racing 440 a '97 XR for me.
Only thing I would say....you like lots of ho' power, get a CRF :thumbsup:.
Have Fun ~Jim
My XR is a 1988. I am in process of restoring it (inspired by the bike building shows). Also pumping up the power a bit (300 kit). Cant wait to ride it!
You will not have a problem if you use a high quality oil.
I prefer full synthetic but go with at least a semi-synthetic MOTORCYCLE oil with a JASO [MA] rating. The clutch is the weak point here. Be sure to run H/D clutch springs. I recommend to run the full recommended amount of oil but running too much can cause excessive foaming in the engine.
Cher'o,
Dwight
Ahh, the dremel. Thank god im not the only one who's tried that.
I added the Scott Summers 250 oil cooler kit ($391.95) to my 280 just to be safe and to extend the time between oil changes. The kit is complete and installs easily. Check out http://www.srcinc.net/
