Need front forks rebound fixes
I just put in fast-mini front springs and a works shock on my ttr90. My problem is the rebound in the forks is way fast anybody know a good weight and amount of fork oil? & will tall bars need longer cables? if so where can u get them?
I went with 30wt in some CR80 forks where I had the same problem and worked pretty well. Had to run a lot less compression.
My ttr forks are not adj. but thats a good starting point if that don't work i can dump it out and try something else.
