The storm fuel mix crew for a crf450 or a jd jet kit ???????
I was intrested in the storm fuel mix screw for my 02 crf450 and how affective it is when you are riding in high altatude. or the JD kit better??
thanx
The fuel mixture screw only affects idle mixture. It cannot adjust for high altitude riding beyond the idle setting.
The jetting kit will correct jetting over the entire throttle range from idle to full throttle and gives adjustment for sea level to 12,000ft elevation. It has everything needed.
James
