Corner Clutch???
Need some help on cornering. Being a slow older rider but wanting to get better, plus coming off a 2 stroke, what are the techniques for clutch during tight and berm corners?? Any advice would be appreciated :cry:
You generally don't feather the clutch like on a 2-stroke. On some corners you don't need to clutch at all if you are in the right gear. On tight corners, I will generally pull in the clutch on braking and then "dump" it when I am ready to hit the throttle.
